Vin # Locations
q3112
doha
ali
c35
Hello can any body tell me where I can find the vin for my track gmc 1985 longbed stepside locathion on the frame and other locations difrent than the one in the dashboard
J Knight
Baytown TX
82 Chevy
350ci
Other than the dash you can find it on the spid sticker on the front inner fender, the sticker in the door jam, and stamped in two places on the top of the right frame under the cab about where the passenger sits and between the holes for the front bed bolts.
q3112
doha
ali
c35
thanx for replaying
Here's a pic of the partical VIN # on an 85 C20 frame that would be under the cab.
I'm not sure if the C is Chevrolet rather than GMC, of if it's C for C series truck being a 2wd, then the last digits of the actual VIN. If I had to guess, it's for Chevrolet since the part # on the side of the frame would designate a 2wd C series frame.
Also pictured is the part # of the frame and date code on the passenger side frame rail behind the forward section of the fuel tank.
And if the driver door is still OEM, there is a GVWR sticker on the door with VIN and Month/Year of Manufacture. Usually faded and very hard to read.
rwljpl
Alabama [AL]
Rich
This is the side of the frame- what do these numbers tell me?
rwljpl
Alabama [AL]
Rich
Better picture
DanMcG
Central NY
k10 k10
Nice clean frame....that is probably a part number... vin is on top flange, pass side near or under rear of cab
Craig 85
Nashville, TN
454/TH-400/NP205
My '85 K30 has it on top of the right frame rail in the middle of the gas tank.
CSFJ
It seems that the one tons had the stamping farther back, in the fuel tank area. The half and three quarter trucks typically show up under the cab are. At least that seems to be the prevailing trend whenever one of these vin threads get posted.
Keith Seymore
Motor City
Keith Seymore
4.3L
Nothing, really.
Part number, date code and supplier information.
K
Keith Seymore
Motor City
Keith Seymore
4.3L
It's going to vary a little bit by final assembly plant (there were 7 plants building squarebodies) and model (which affects available real estate on the frame where you can put the VIN).
K
Keith Seymore
Motor City
Keith Seymore
4.3L
(sorry for replying to this old one)
In this case the "C" is for Chevrolet (as opposed to "T" for GMC).
So the partial VIN would be:
CFJ123456 =
C = Chevy
F = 1985 model year (A= 1980, B='81, etc)
J = Janesville
123456 = sequential portion of VIN
A GMC would be TFJ523456, etc
K
jlyon1006
