SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- C20
I've always run cork, really for no other reason other than they rolled out of the factory that way. My method with tin factory covers has always been to peen the covers if needed and run the longest spreader bars I could get. Glue the gasket to the cover and install, unless there is a history of leaking or an obvious flaw in which case I might silicone the engine side (I like right stuff). However my truck started leaking enough oil from the cover gaskets to make an oil burning smell at idle with the A/C on about a month ago. I don't really like the process or meticulousness that one must go though to make cork seal up so I thought I'd try something else. Did a little looking around and settled on the Fel-pro permadry units the ones with the metal core and rubber on each side of the metal. Looked like a good quality product. Well they never really did seal fully. I've smelled it albeit much less every time I've driven the truck since then. At first I thought it was just from residual but over the past week I was able to start to see just a trace amount on the left side.
Today I found the time to take them off. Sure enough there was an area where you could tell oil had seeped past the gasket on the block side. Both sides were doing that. Wished I'd pick up a cheap set of corkers, but I hadn't. I need to drive the truck on Monday so out came the right stuff and thin bead applied to the engine side. To me that sucks. Oh well. Hopefully this will do the trick if not I'll be going back to cork. Curious what other folks have had for experiences with rubber gaskets on tin covers.
Here's a few pics of the covers after reinstalling them, if you can see them in there lol.
