texasmike
- Sep 18, 2018
- Conroe Texas
- Mike
- C10
I have a an '84 LE9 engine the original re-built Qjet carburetor and new CARDONE HEI distributor #84-1845 for a 1982 model (no electronic spark control like the 84 and 85 models). All of the emission systems have been removed and I've been trying to time it for maximum performance. I even broke down and bought a pricey dial-back timing light, which I really like. I've read all of the articles and decided that manifold vacuum is best for me. My problem is that my 19-20" hg produces 25* advance. With 12* initial, 18* mechanical and 25* vacuum, I'm at 55* max at highway cruising speeds. I understand that I should shoot for 34-36* for total time so that means I still need about another 5* of advance, making max advance at 60*. I've read to never exceed 54*.
I've seen a video where a guy sticks an 1/8" Allen wrench in the vac port of the can and adjusts the vacuum produced by turning the wrench one way or the other. I tried it and turned it four times clockwise and it stopped. I then turned it counter clockwise and after ten turns I stopped for fear of backing the screw completely out and losing it in the can. I decided to put it back in the position I found it and seen if anyone has any experience adjusting this particular distributor.
