- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
I did have lots of junk in my old pump even after putting a filter in, so i wouldnt be surprised if it caught a lot. metal bits that is. BUT, yes the belt is good, its the new belt. It isnt slipping, or at least makes no sound to indicate that. But I did some research on ps lines and it sounds like one of my bends is likely keeping an air pocket. So I will fix that with a shorter run of hose and new hose(not bad, but its been a couple years and run a little long)“Choppy” power steering could be belt slippage.
Eliminate that first. Sounds contradictory to what I said about not needing double belts but if it’s slipping, imo 2 belts is a bandaid.
Make sure belt not glazed, or new belt.
Same for pulleys. Clean and scuff with some sandpaper.
Or the old time bandaid. Shoot it with some belt dressing.
Do that before condemning hard parts.
Those PS filters unless plugged do not restrict flow imo. They’re pretty coarse screens that catch chunks not minute particles.
Im condeming some hard parts because my ps pump has a good amount of wobble in it. Like shaft end play, the one i took off was shot and lot worse than i thought. But i also have never had a new or unworn saginaw to compare it too. The only PS pumps i encounter are ones i remove and replace, i guess i never check the play or wobble. I do need to increase idle speed a bit on truck when it is on the kick down, that i noticed a wee bit of throttle helped a bunch, but that tells me maybe it was the oversized pulley. at 600-700 rpm i would think that should be enough for full assist. but i also have to consider that my front end permanently is heavier than most trucks let alone square by a couple hundred pounds, i have HD springs, and in winter i have a few hundred in extra plow. So maybe im an extreme example of needing more ps assist than most trucks? esp if the pulley came off a car or something
