- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I have what I beleive is a 2/4 drop kit that I pulled off of a truck I bought for parts and scrapped. It all there with exception of the shocks since the shafts were rusted I let those goes to scrap too. So what's included is the Rear Frame front hanger brackets that you'd remove the OEM hangers and install these. The shackles for the rear spring hangers of the rear end. Then the front coil springs, and front drop spindles. It came off of an 86 Long Bed truck, and I assume it should fit any 73-87 1/2 ton truck, or 73-91 1/2 ton 2wd Blazer/Jimmy or 2WD Suburban. I was thinking of Craigslisting it for $200. Am I on crack or it that reasonable???
