austinado16
- May 25, 2012
- Central Coast, CA
- Todd
- 1990 w/307k miles on the clock
- GMC V1500 Suburban SLE
- 5.7L TBI/4L60/3.42's
I tow in pretty severe conditions, and have made a few modifications to help keep the coolant and transmission temps under control. A couple years ago I upgraded the original small block 3 row radiator to the bigger 4 row version that I saw offered in the 1/2 ton, 454 models. Nice, but I still had my eye on one day installing the much longer radiator that was used in the 2WD, 3/4 ton, 454 models.
Been trying to do some research and collect all the necessary parts, and finally, today was the day....
Some helpful part numbers and other misc. info:
-Radiator mount pads, 4 needed. LMC Truck part number: 32-0972 at $4.95ea
-Upper radiator hose. NAPA part number: 8396
-Lower radiator hose. Re-use the original small block's hose.
-Connections for transmission lines: Same as original small block radiator as well as the shorter 454 radiator.
-Spacer needed for the radiator fan on the small block: Approximately 3" thick and you'll need to come up with longer bolts for it in order to mount the fan to the water pump. I had already done this specific mod when I upgraded from the 3 row radiator and it's "deep" fan shroud, to the 454 4 row radiator, with the shallow shroud.
-I wound up rotating the driver's side horn 90 degrees, so that it wouldn't block the airflow through the upper-most hole that I'd cut into the core support.
-I used a Greenlee "Slug Buster" electrician's tool to cut the holes in the core support, and then cut between the holes with a jig saw, in order to create the oval openings. I purchased the slug buster kit about 2 years ago when I was installing a big natural gas, whole house generator.
-In the first photo, below, that's a stock GM pusher fan, in front of an 11"x11"x1.5" (B&M Super Cooler/TruCool) transmission cooler. The cooler on the driver's side is the original GM engine oil cooler.
-The stock radiator core dimension (not including the tanks) is 19" x 28". The longer radiator is 19" x 34" and about 40" total width.
-Transmission cooler in the right radiator tank can be about 8" tall, or 11" tall. The radiator I'm installing has the 11" trans cooler. It also has the engine oil cooler, in the left tank, which I won't be using.
Core support before installation:
Cutting the outer air flow holes:
Cutting the inner core support air flow holes:
Comparing the 454 standard radiator and shroud to the longer versions:
Installation complete:
Final inspection and ready for a test drive:
