Preston
- Jan 25, 2019
- Mechanicsville VA
- Preston
- k10
It could very well be a Ford u joint the drive shaft came from a junk yard was setting with a pile of other loose driveshafts. I was looking for anything longer than 6’ had it cut down and welded a 32 spline front shaft from a Monte Carlo, while keeping the rear yolk in place and fitting it with a u joint that matched the rear in my truck. The u joint came with extra caps the driveshaft end used external clips and the end that hooked to the rear end could go either way c clips on the inside or the external spring clips. Is the site a place were I can order one ?
