U bolt dimensions
Shields
Kelowna
Dayton
as the title says I just wanted to verify the U bolt dimensions for a 12 bolt. 3" width x 7" length x 9/16 thread right? I have a belltech flip kit installed and need to know before I drop $80 on u bolts a local shop will fab up. Does the flip kit use a stock U-bolt?
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
A bit late,
The 12-bolts are indeed 3" axle tubes. For length you need, you can take the thickness of spring pack (probably 3-5") + the axle tube diameter (3") add on an inch for the nut and a half inch for threading.
If I remember correctly, 9/16" does sound correct.
$80 for a set of ubolts is quite expensive..
Was about $40 at a shop near me and that was for extended ones as well.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Bolt diameter is 5/8"
78silverado
