Tuning for altitude
RawkerStatus
California
Angel
Suburban K20
So been messing with a holley carb, I'm at 4500 feet and the jets that came with it are for sea level. After research, they said to drop down a jet size for every 2k feet. The carb came with 66 jets. I went down to 64 jets and it ran better. Timing is at 32degrees total. What do you guys think of the spark plug? This is cylinder 1.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
The electrode is neither brown, nor black nor white. Reading plugs with modern gas isn’t really as telling as it once was.
What protocol are you using leading up to pulling the plug? WOT, normal driving, babying it...?
RawkerStatus
California
Angel
Suburban K20
This was driving 5 miles at 65, shutting down and pulling over and checking after a few minutes cooling down.
http://www.bgsoflex.com/holley.html Holley jet correction calculator
https://www.crankshaftcoalition.com/wiki/Reading_spark_plugs article on reading plugs
I agree with rusty platinums dont belong in a sbc
Thanks I've been looking for a calculator. Blue Print recommended those plugs since they run the 906 heads.
Rusty Nail
Rusty
350sbc
Oh yeah. Vortex heads.
I didn't read that.
*edit
I didn't read it cuz...lol?
Hold on... Was I suspossed to know that?
I don't believe it's assumed. Vortex heds are not the typical cylinder head in the majority of members' trucks.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I don't think 5 minutes of driving is long enough to get you an accurate reading. I'd run them a week and check.
I wouldn't be running the plugs based on the head. I'd be running them based on the fuel and ignition system. If you aren't running fuel injection and Vortec ignition, I'd switch back to a standard plug. The older HEI's tend to not like the platinum or Iridium plugs and especially not anything over a 0.045" gap. I think those platinum Vortec plugs were gapped at 0.060" which could burn up the HEI coil pretty fast.
RawkerStatus
California
Angel
Suburban K20
My bad, so it's a 350 Blueprint engine. 220 intake, 224 exhaust with .50 duration at 114 degree lobe separation cam. 609 heads with the plugs gapped at .45 per Blueprints recommendation. I've gotten about a max of 14 inches of vacuum after tuning with the 64 jets. Theres a hesitation at take off where I have to feather the throttle to get it not to stumble.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
check the accelerator pump, there should be zero slop in the linkage and it should squirt at soon as you move the throttle.
RawkerStatus
California
Angel
Suburban K20
It squirts pretty good. I'm wondering if it's the wrong profile for the weight of the vehicle.
SquareRoot
So the air thinned out with the rise in temp. Therefore, it was a lean stumble. This is why carburators suck. You get to tune them every time the weather changes. Thank goodness for efi.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
Temperature defiantly makes a difference. I got a WB wideband air fuel ratio gauge , was planning on using it to tune and then remove it. I also have an APT Adjustable part throttle this allows me to adjust the cruise mixture . What I found is if I set the cruise mixture at 14.7 : 1 in the winter then when summer comes around the mixture will richen to 13.2 : 1 . So I made the Air fuel gauge permanent and now i can just tweak a couple screws when the seasons change to keep everything dialed in.
jlyon1006
