Barkett
- Aug 24, 2020
- Dover, OH
- Mark
- C-10
Greeting everyone! This is my first post, but I have been reading this website for the last two years.
Quick backstory... About two years ago I started to fix up my grandpa's 1977 Chevy C-10 Cheyenne with 77k miles. He had it parked in the basement for the last 30 years, always meaning to fix it up but never quite getting around to it. With the help of this wonderful site I was able to: replace the bed with an clean 86 and relocate the gas tank, replace both fenders, replace the entire brake system, fix a small transmission leak by replacing the filter and gasket, install new tires and rims, replace the high-pressure power steering line, replace valve cover gaskets, install a new radiator and thermostat, install new fan and clutch (which was missing), tear apart clean and rebuild the 4-barrel quadrajet, and tune the engine well enough to drive it around for the last year (~1000 miles). I just got the truck painted (on the cheap ~ $900), and will be getting a Rhino liner this Friday. So thank you all very much for your detailed posts, I truly appreciate it!
The only issue I have with the truck it during the first start of the day. The engine always turns over and starts, but will stumble and die within 3-5 seconds. I crank again, the same thing. Usually, by the third crank, it will idle well enough to put into drive and head down the road. After a block, it idles and runs perfectly. After the first start of the day, it starts immediately and idles perfectly each time after, even if it has been sitting for 8 hours at work. I have adjusted the choke thermostat per the manual and checked the timing and both are in line with the service manual. What could be the issue here?
I could post pictures or videos this evening if anyone thinks that would be helpful. Thanks!
