Truck 12 bolt carrier
1973c10
Don
Can you put 3.73 gears on a carrier that had 3.07 gears on it
or do you need a different carrier ??
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
you can get any gear set you want . thanks to Retro I found out that my new truck has 4.11 gear and a oem locker in it
1973c10
Don
Do I have this right I need to use a
Chevy 12 Bolt Truck 3.73 thick ring and pinion set with my 3.07 carrier
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Get the thick gear set. Motive sells a thin set with a spacer to adapt it for the 3.08 carrier, AVOID THIS ONE AT ALL COSTS! I sheared every ring gear bolt and pushed them through the diff cover, gutting everything I had done. The thick gearsets will work with the 3.08 carrier.
ben_swager
