Transmission Indicator
Kilian
Wisconsin
K
C2500 on its way to a K2500
Something broke behind the dash and I no longer have an indicator of what gear the transmission is in. This is on a 83 GMC C2500. How difficult is it to repair the indicator, and what are the usual suspects to break in the indicator? Thanks.
carfanatic63
Houston
Austin
C15 SWB
It is pretty easy. There is a tab with a wire connected to the indicator that just clips on the column. You have to take off the bezel to reach everything but once your their, it is a simple job.
Kilian
Wisconsin
K
Is there any way to repair the cable? I opened up the dash last night and just the cable is broken.
Crispy
Carbon County, Pennsyltucky
Suburban V1500
I would try to either run some fishing wire through, or try a thin gauge butt connector.
lumpyc10
oregon
Dave
silverado
Braded fishing line
Craig 85
Nashville, TN
454/TH-400/NP205
Picture hanging wire is an option too.
Kilian
Wisconsin
K
Turns out that I had a spare cable on an instrument cluster that I bought at a car show. However, this cable is the "new style" with a different clip than what is on mine. I tried to open up the little clamp that was holding the remnants of the original cable on the original clip, but the clamping "ears" broke off. In the end I was able to mount the newer style cable clip to the column housing. How is the newer style clip actually connect to the column?
jlyon1006
