TRANS SWAP
Jeffb1961
Lake Isabella
Jeff
c30
I HAVE A 1986 CHEVY C30 DUELLY. I WOULD LIKE TO CHANGE THE 4 SPEED MANUAL TO A AUTOMATIC. IS AND CHANGES THAT HAS TO BE DONE TO THE TRUCK. AND SHOULD I GET A NEW STEERING COLUME WITH THE AUTO SHIFT HANDLE ON IT.
Strick
Dunn, NC
Harold
C20 Crew
I would change the column to an auto when doing the swap. Are you putting a TH400 in? Also, IF your truck has a tilt column with the manual it will be worth a little something.
HS
  • Like
Reactions: WFO
Jeffb1961
Lake Isabella
Jeff
c30
I'M NOT SURE ON WHICH TRANS TO PUT IN. ALSO IF I CHANGE TO A AUTO WILL I HAVE TO MAKE ANY CHANGES TO MY FLOOR BOARD?
NickTransmissions
Las Vegas
Nick
Id do a 4L80E with a stand alone controller. Best auto trans GM has ever fielded, IMO. You should have room in the trans tunnel but you can always take some measurements, post them and i can give 4L80e measurements to confirm/deny fitment.
Also, why all caps (yelling)?
BLAKMAX
