TPS sensor wires
martingmc86
california
martin
gmc sierra 1500
v8 5.0
Hey guys,I have a 86 gmc sierra 5.0 4 barrel carb I need help identifying my TPS wires going into my sensor I need to know which one is the TPS signal and which one is the ground wire? Can you help me please?
Hey guys, I need help identifying my TPS wires going into my sensor I need to know which one is the TPS signal and which one is the ground wire? Can you help me please?
We got another one!!!!! Year? Model? Engine?
Busy and working from memory,I'll look harder later. From memory you have a yellow wire it's 5v reference ignore it check continuity to ground with your DVM on the other two. 1 will read open it's signal one will read o it's your ground. If no yellow find the 5 v wire and proceed as above.
Home now, looked for you,grey is 5v reference,blue is signal, black is ground
martingmc86
california
martin
gmc sierra 1500
v8 5.0
Ok that’s makes sense So with that being said I need to do the following splice in to my tps signal wire that should be (blue) and splice in to my ground reference wire that should be (black)
jkrenzel
