TPI parts worth swapping?
The dual sync distributor has a cam and crank sensor in it. You can get a flat cap for it when using it only for the sensors. No need to change the timing cover an add the sensor there with it! I honestly want the coils on the VC so people go wtf?
The self tuning is decent but it's only for the fuel trims. You need to manually set your desired afr, timing, accel enrichment, cold starts, etc. I don't like how they advertise them because people think it will "learn" everything on its own an you shouldn't have to touch it. People get suckered in by that an have high expectations an then are pissed that they have to adjust things. I've about stopped working on Snipers because of people's attitudes and shoddy installs....
That's good to know about the tuning.
I know there are ways of using a distributor, or variation of one, for the cam sensor. But I have it in my mind that a cam sensor right on the cam gear is a more accurate way of doing it. Whether or not that's true... I can't say for sure. But my mind still wants a sensor in the timing cover, lol.
You have a good point about the coils on the valve covers though. My whole thought process was to have it all stock appearing for the casual observer. But it sure would be fun to have people confused about what's going on.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
I was thinking $350 for everything off the engine and under the hood. TPI intake, intake runners, air chamber, injectors, feul rail, fuel lines, vavle covers, accessory drive brackets, water pump, power steering pump, air pump, belts, pulleys, mounts, brackets, nuts bolts, doodads and thingamajigs, and ttw whole engine side harness.
But I'm open to offers money wise and, picking and choosing parts. Have 2 big boxes, and the entire back of a suburban full of Corvette parts, that I'm happy to get rid of.
bluex
Spartanburg SC
C15
Look up the distributor an see what is all about, it might change your mind. They work well an are used on lots of high end stuff. If you want to use it on a holley ecu it's plug an play.
You can certainly go with one in the timing cover but they take much more effort to setup an get right in the tune.
bluex
Spartanburg SC
C15
Good bookmark here
If your plans don't include anything above a stock type 305/350. I definitely wouldn't run one on the factory pcm these days. There are to many aftermarket alternatives that are way better than the Ole OBD1 stuff. They are a nightmare to try an tune for anything modified, if you can find anyone to do it!
weedoz
