Towing with an old truck
Strick
Dunn, NC
Harold
C20 Crew
Yeah, it's very tongue heavy. But what does the surface contact area of the trailer tires have to do with weight distribution? With all else being equal (tongue weight, axle spread, trailer length, etc) the truck itself doesn't know the difference if the trailer has duals or singles.
When you load the WD hitch you'll see the effect in the vehicle suspension. Works great for tall profile trailers as it puts more of the weight back on the trailer axles and helps reduce sway. The dual wheels goes without explanation.
So you are saying that a weight distribution setup helps with sway? I thought the whole point in it was to get weight off the rear axle and onto the front axle? The only time I ever see any type of weight distribution setup, it's on a camper being towed by a lighter capacity rig.
SirRobyn0
Well most all of you already know i tow and haul. For the sake of the spirit of this thread I'll give an over view.
Up until last fall I had a farm plus a day job. It was not uncommon for me to drive the truck on my commute to the shop, but it also got used extensively for the farm. It was no uncommon to find me driving several hundred miles for feed. Wherever I could get the best deals. If I was bringing back ton or less it went in the bed, if it was more than a ton it went on my trailer and of course I towed it with my square.
The truck is an 84 305 beefed up 700r4 and it was a 3.41 semi float now it's a 3.73 full floater.
my heaviest feed loads were around 7K. How did it do towing that kind of weight. It did just fine and never left me on the side of the road, never got hot or gave me any trouble. But you have to have reasonable expectations of the trucks equipment as far as what it will tow and how it will tow. What I'm saying by that is basically it was stable and safe. Trailer brakes worked great and it always stopped good. However going over mountain passes and ridge crests were slow. And thats OK.
Redfish
Prairieville, LA
Andrew
V1500
@bucket no, the 2500HD springs are NOT weak. I have done things with the 3 different 2500HDs that would have sent the designing engineers into cardiac arrest.
I am old enough to remember that these trucks and the equivalent Fords and Dodges of the '70s and '80s moved whatever needed moving. There were no diesel pickups worth towing with in those days.
I have become spoiled to the Torque of my Duramax and the stability of a modern chassis. But I remember when my Dad had to pull things for folks that did not have enough truck. With a '77 GMC 1/2 ton SWB 4wd. Times have changed.
I guess I just don't understand then. I've pulled the same loads I described earlier with dually trucks and also C4500's. It's not much different. I've pulled upwards of 14k on single tandems with single wheel squarebodies and have been perfectly comfortable. Some of those loads have had a fairly high center of gravity as well, and a bit of frontal area. Like so:
idahovette
Weiser Idaho
Perry
K20-K10
@bucket Andy, maybe your comfort level is a lot different than other peoples????
burnt
