- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
how were they installed? They should be free floating on the piece they pivot onThe ramps can’t be removed.
You welded them on? should have made them removeable
op should consider a adjustable height hitch, putting trailer tires at maximum PSI for stability/weight rating
Then also if you load a suburban on it, if your ramps cannot be removed, you should use tires or something strapped to the ramps to protect the truck, then strap the ramps lengthwise with the trailer to gently hold them up against the truck. should have designed a bar that holds them up.
Also your trailer should be supported with 6x6 blocked up at the end of the trailer (ramps with these supports can be fabricated in the future)
This kinda strapping allows you to hold ramps at various angles.
