Tired of the screaming small block!
hirschdalechevy
norcal
rich
k-30
Thanks that's the kind of information I'm looking for. 063 215 290 are the last 3 digits in casting numbers correct?
That crew cab is freekin awesome by the way!
Thanks , and yes on the last three , my heads are , (two sets) , #3964290. My crew cab heads have major porting and bigger valve's and a bigger cam , better valve terrain as to run out a bit better , also port matched intake.
Rusty Nail
Rusty
350sbc
Don’t forget to get some fagotty diamond cuts on them black wheels.
Looks like some chick got jiggy with a BeDazzler on your black wheel bro !
Na na na nah na na nahhh :gay: :poop: :waytogo:
Clutch
Dirty Jersey
K30 Silverado crew cab dually
L82 350
Ok guys I lost a cam Loeb on #8 I think the cheapest fix is an RV Towing Cam Kit because I can't afford to rebuild a big block right now so I was looking on eBay at cam kits. For around $200 it seems I can get Cam lifters gaskets zinc and assembly Lube but there's several different lift and duration camshafts I was wondering if you guys could recommend one for my 350 Chevy it's got Mexico heads and an Edelbrock Performer intake and it's an L82 bottom end that's been rebuilt by who knows who that's probably why it wipe the cam. I should probably order by tonight so that I have it for next weekend so any recommendations would be greatly appreciated thank you
Rusty Nail
Rusty
350sbc
MY choice?
Easy. L46 baby, yeah!
350 hp/ 350 c.i.
Dooooo eeetttt!
:headbang:
Fantastic truck cam.
Hi! I found this on eBay and thought you might like it! Check it out now! http://r.ebay.com/cnqEX1
Clutch
Dirty Jersey
L82 350
I pulled the cam out of the small block today now I know I could never get it to run right the previous owner was an idiot. I checked the grind number in this is the cam that was in it
I'm surprised they got at the run at all
Rusty Nail
Rusty
350sbc
:jawdrop:
Omg lol!
Maybe you oughta toss it back in and retard it say, 6°? 4?
Clutch
Dirty Jersey
L82 350
:jawdrop:
Omg lol!
Oh I tossed it just not in the truck
Rusty Nail
Rusty
350sbc
Woah.
Kinda begs the question what did that engine came out of that made you think it was a good fit for that truck? If you'you're gonna say it came out of a '77 Monte Carlo with a full rollcage, no dash, no glass, and four (15x12) BARTS on it with a 5 gallon fuel cell in the trunk i'm gonna have other questions...lol
Clutch
Dirty Jersey
L82 350
Woah.
Kinda begs the question what did that engine came out of that made you think it was a good fit for that truck? If you'you're gonna say it came out of a '77 Monte Carlo with a full rollcage, no dash, no glass, and four (15x12) BARTS on it with a 5 gallon fuel cell in the truck i'm gonna have other questions...lol
I got the motor with the truck the guy I got it from said he built it for the truck lol the same guy put a 1/2 to master and booster on it and T-ed 3/16 brake lines to all the wheels I all ready fixed all that
Rusty Nail
Rusty
350sbc
Is there a build thread?
This is very entertaining! I'm sure we'd all like to see!
Matter or fact, don't you guys think there should be a previous owner horrors thread of some kind? What does it take to make it happen?
Clutch
Dirty Jersey
L82 350
Suffice to say I'm a body man and a G Body guy so there is actually a build thread but it's on a different forum. I'm the gbodyforum there's a thread called square body crew
Clutch
Dirty Jersey
L82 350
I got it back together I am not a mechanic I am not an electrician I still can't figure out how to make my oil pressure gauge work I still can't figure out how to make my gas gauge work but it runs however it has a little bit of a shake to it maybe I've got a valve too tight I'm not sure I was chasing vacuum leaks and timing all afternoon it does run way better than it did before. It's not finished I still got to put the grill and stuff back in it but I was tired and my nerves are shot!
If you check out my build thread is a really good read I've evenI've even had to section frame horns in this truck because the previous owner sold them off to put a semi truck front bumper on it. It had no body mount bolts the engine was sitting in there on Chevelle clamshells and the cab was resting on the transfer case. It's come a long way
brentjo
