77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
With that size tire I would not even waste the money on gear's for half ton stuff , I would jump up to 8 lug before anything. Another thing if you do a lot of freeway driving you need to be careful with low gear's. The pinion get's small with low gear's and it spins faster with low gear's and over heats the gear oil. I have 4.88's in my crew cab with 44's and in the summer going down the hwy. at 70 for say 40 miles it spits out the vent tube a bit and you can't even put your hand on the diff cover. I was told by my gear guy that 4.88's was max for freeway use because I was going to go with 5.13's , glad I did'nt
Have you ever thought about putting on some of the aluminum diff covers that have cooling fins on them? Some of the guys that tow a lot are running them. Some even have a tapped hole for a temperature sensor.
