- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
If you still have the stock low-compression pistons, you should be able to run 10-12* advanced.
One of my Camaros had a 350 w/305 heads when I bought it. The PO thought (and also told me) it was a rebuilt 305. It felt strong and wasn't a bad motor at all. I ended up pulling it later on, and that's when I found out it was a GM crate 350 shortblock with late 70's 305 heads, although they were ported and polished.
Anyway, I'm not really sure why everyone always knocks this combo. For a poorboy just using what he already has, it's not a bad setup, IMHO.
For a poorboy using what he has they are good. Past that, I only knock it because you hear of some who THINK they know what they are talkiing about, to go FIND AND BUY a set of 305 heads for your 350, that it raises compression and makes a ton of horsepower. WRONG. It will increase compression and will ONLY make low end torque, not horsepower, and they run out of breath at low rpm. They are NOT a high performance good option. Great for maybe an RV cam pickup that is pulling a heavy trailer and that's about it. And if you're truck is geared to low, they really won't perform well since at rpm over about 2000, they're done making good power. Sure they will work, and they will run with a little grunt, but with the small runners, small valves many times, your ONLY advantage is a raise in compression and many times have to retard the timing taking away even more power than you gained due to detonation. Use them if that's what you have, but not for a street/strip rig. Street/Strip rig needs to be able to breathe good at 4000 and higher rpm depending on your cam choice.
