Timing light recommendations
chevytech87
Tomball, TX
Brandon
GMC R1500
Good evening everyone!
I finally got my new motor to run and idle today. Took a lot longer than expected to get everything together, learned a lot of new things over the past month. I’m fairly confident I’ve got my base timing kind of close, but really want to put a light on it to check. Unfortunately, nobody in the shop has one anymore. I’ve been advised to find one with a dial. Any suggestions on a unit that isn’t junk and what flavor (digital, dial, neither?) I should be after? This is my first old tech project so I’m a little clueless as to what’s good or bad. Like I said, been learning a lot and having a blast. Very different than my day to day dealership work.
All suggestions appreciated!
gmbellew
Kansas city
glen
suburban 1500
I just have a basic bosch one with no dial. works fine for setting base timing. checking for spark, etc. i think I got it online at O'Reilly 4 or 5 years ago for $50. if you want to check total timing and things like that, you'd want one with a dial.
I've got an old Sears timing light from the 70's. No dial. Not trying to toot my own horn, but I have no trouble checking total timing advance without a dial, just by gauging where the timing marks "would be" if the timing tab was longer. Yeah, I could be off by a degree or so, but I don't have any high strung race engines.
Putting a timing tape on the balancer would make a dial not needed as well.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
All anyone needs is a standard one. Ive got one with a dial tho, its not digital. I like the dial for finding out maximum advance when tuning.
chevytech87
Tomball, TX
Brandon
GMC R1500
All I really need is to set base for now. I like the degree tape though, another thing I didn’t know existed! Pretty neat. Slightly unrelated, it seems to idle high, around 750-850ish. The cam is a roller 236/252’ at .050” with .565 lift on 110’ lsa. Maybe that’s just where it needs to be?
RanchWelder
Earth
Blazer
350ci
Rickf
Grafton NH
1974, 1954 & a 1937
I've had a snap-on MT1261 for 25+ years, bought it used, don't recall how much I paid, must have been cheap because I am.
I’m using an Innova light with setback dial and a tachometer readout, and IIRC it was about $100-110. It seems to be good quality, and it has all the info I need in one package (both timing and rpm) to check my vacuum and mechanical advance.
I first tried buying a similar light from Harbor Freight, but returned two of them because the tach readout was incorrect. Good quality control - all of them have the same inaccuracy!
matt4426
NE Ohio
K35
2nd the Innova dial back timing light. The light is very bright. The dial back feature is way nicer than trying to use a degree sticker that always flies off the balancer. O'reillys and other auto parts stores carry them in stock.
matt4426
NE Ohio
K35
That's a pretty big cam. It will probably like alot of initial advance. You running vacuum advance?
hogdaddy
Alabama
mike
Scottsdale
chevytech87
Tomball, TX
Brandon
GMC R1500
No, I’ve got a hyperspark setup with a sniper. So allegedly I can set timing for startup, idle, etc. in the controller. We’ll see. The cam is definitely larger than I was led to believe, this was a mystery motor I got from a coworkers abandoned project. Many specs unknown, lots of fun
seanhatesregister
