Time to clean out my garage. Bunch of leftover parts.
trukman1
USA
Gary
K5 Blazer
5.7 L (350)
Interested in A/C dash bezel if brushed aluminum shipped to 45431...price?
Also, next in line for duct under steering column if available. (If donnieray doesn't buy it.)
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
Hey guys, sorry about the late reply, I've been out of town a lot lately.
The AC duct that goes under the steering column and the 700r4 gear indicator shipped to 27870?
I'll get you something together tonight. I'll have to figure out which duct that is. All the pieces are just sitting in a box in my shed right now.
The bezel is aluminum, but it was spray painted black. If you are still interested I will get a picture. If not I may attempt to get the paint off at some point.
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
I apparently do not have that piece of A/C ducting.
Here's a picture if you're still interested.
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
I can do $12 shipped on the indicator.
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
Ok. I'll send that in a few. Thanks. You don't have to break your neck sending it out. It's for a project.
73c20jim
Tombstone, AZ
Need AC bracket from rear of AC to SBC manifold. Connects with two bolts to intake.
Might you have one.
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
Might you have one.
Got a picture of what exactly you're looking for? I have some assorted brackets sitting around but I'm not 100% on where all of it goes.
rpcraft
Robert
LS 6.0 364 CID
Crossmember, 208 adapters shifter linkage and the 208 shifter lol. 42210 is my zip just PM me when ever. About to do a 4l60E swap with a 208 and I literally need all of that lol.
FYI that short foot adapter will only work with very specific years of the 4l60E. There are versions that are the one piece body and still have a 4 bolt tail shaft housing. If you have that then rock on. If not then you will need to find the 4l60E adapter out of a 1998 and later and you should still be OK to use the W crossmember and parts that match it.
jlyon1006
