Things I wish I knew
newguy11
New England
Private
C/k 10
Recently completed an engine build and like the title says….
Concerning aluminum intakes or in my case a used edelbrock performer. I wish I had drilled and heli-coiled the water neck and distributor bolt holes BEFORE I installed the engine.
Note to self aluminum intakes and steel bolts corrode over time.
1STLS1
West Phoenix AZ
MIchael
When you have dissimilar metals in coolant, the coolant acts as an electrolyte and a small electrical charge is created causing corrosion. It's important to make sure everything is grounded properly including your aluminum radiator if your running one. Also you can run a sacrificial anode that will deteriorate before the aluminum. This is why you change your coolant, it turned more acidic and is a better electrolyte.
It also works backwards, you can use electricity to remove corrosion.
zapattack
