the viper mistake
yevgenievich
Place
Name
Year
Model
Size
Ordered wrong year dakota parts. Waiting for more correct ones. Also went ahead and ordered new rotors and pads. And painted on door handle. All th doo handle does is actuate a mini switch. They could have just made a button like a c6 corvette instead. Went in to a door handle because passenger side window stopped going up.
yevgenievich
Place
Name
Year
Model
Size
And door window mechanism is apart.
Originally I thought door panels were not fitted correctly because window motors were replaced. But looks like all they did are speakers and window motors are original
yevgenievich
Place
Name
Year
Model
Size
Was getting 12v at the connector but must be a bad wire or switch. Regulator works fine outside the door. Plug in to the connector and up does not work
yevgenievich
Place
Name
Year
Model
Size
The issue with the window is likely in the switch because it reverses polarity as there is no other ground in the door it self. But decided to check the wiring. And then as couple of wires were bad decided to replace all wires that run through the hinge area. That i where pieces of the corvette come in. Unfortunately most of the exact same color wires are 20awg in the corvette instead of 18awg that i need. Some colors will not match exactly
yevgenievich
Place
Name
Year
Model
Size
New window switches are actually available, but cleaning the old one a bit for now. Also need to deal with the tie rod ends.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I wish I'd have known you needed that pass window motor because a have s brand new one for the Dakota pass in my garage because I traded it in before I replaced it. Dam the luck. Lol
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
So you had mentioned dodge Dakota parts that have been modified fit the viper? Obviously not all of them im sure.
yevgenievich
Place
Name
Year
Model
Size
Hubs, inner/outer tie rods, and steering rack. Nylon window support piece is from a van. Winshield wiper motors modified van rear wipers(mechanism same but electronics different) and some other bits. Majority of parts are one off
Vbb199
Salisbury NC
Vince
Ah OK.
I figured some of it had to be it's own parts...
4WDKC
Southern Florida
Kacy
Do those pw have a relay for them? My corvette has similar issues and it is because all of the voltage is ran through the switch adding resistance and connection issues, the easy fix is to add relays for the PW and just use the switch to trigger the relays. Oh and add a ground in each door, stupid common grounding or pw will make both quit working with one ground problem.
yevgenievich
Place
Name
Year
Model
Size
The diff and transmission fluid ended up looking fine. Should have left those alone. Broke a seal on one rear caliper while changing the pads, so now ordered a caliper rebuild kit to put new seals in it. Decided to replace the nylon window guide piece as it is known to brake and waiting for that. Also waiting for some brake fluid to come in for clutch and brake flush. Still have not gotten new inner tierods to retread yet, first one killed a die that i had.
yevgenievich
Place
Name
Year
Model
Size
Rebuilt caliper, bled all brakes with new fluid. Need to move on to the steering rack rebuild. Also need to find a new microswhitch for door unlock. Was a regular off the shelf part back in the 90's that dodge just potted the leads to.
yevgenievich
Place
Name
Year
Model
Size
Time to figure out the steering rack. It was leaking some originally and the inner tie rods were actually still good. But when doing the brakes it blew the seals out when I turned the wheels without the pump running. Might as well replace the tie rods and do the alignment after it is all back together.
yevgenievich
Place
Name
Year
Model
Size
Before the disassembly it was evident that seals literally blew out. Mostly apart now . Was not sure if the black remains was dirt or remains of a seal.
yevgenievich
Place
Name
Year
Model
Size
Found the right seal and rack is now in place. Even the steering wheel still pointing straight.
Trans fluid finally filled as well.
BLAZENK5
