c7 on which plug? There are 2 if I remember correctly that go into the ecm
You can do it.C7 is empty on my harness. Is there somewhere i could take my truck to have a pin added?
Ok got pins. My transmission has 3 wires coming from it. Lt Blue, Green, and Yellow.
-Yellow goes to the EGR connector that is D/C.
-Lt Blue wire goes from the Tranny to both the EGR Connector and the Low Vacuum Sensor.
-Green wire.....i'm assuming goes to the brake sensor? (i'll confirm tomorrow)
what needs to be changed for the ECM controlled lockup?
ok. Got the PROMs switched out. Just waiting for the Pins to be delivered so i can run the new wire.
Is it ok to drive the truck awhile? I haven't changed any of the Transmission wires over to the ECM yet.
Yup...I dont think there is an error code for the high gear switch, so you shouldnt get a light.
None that I know of, otherwise I would've thrown one by now with my TH350, I would imagine.
