The last pre-emmisions diesel
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I'm just going to point out that Diesel emissions have been going on for a while and if you have an electronic injection pump it's an "emissions" diesel.
It actually pre-dates that too, but that's where we started spiraling info the abyss.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Did you put a lock or tab on the dowel of destruction?... Or whatever they're calling it today.
KDP. Killer dowel pin. I think "dowel of destruction" sounds better though.
Wasn't that just on the 12 valve engine?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I ampretty sure the deadly dowel pin applied to 12 and 24v's
There is the other one that's bad In 24v diesels, the Mexican (made in mexico) #53 block that's notorious for busting at thinned coolant passages, but that's 98-03 or something, I assume this is newer. I know nothing about dodges, just the cummins' and new ventures that are in their frames
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
89-02 5.9
The 03-04 24v doesn’t need a fix, but the second gen 24v did.
Midnightmoon
Pennsylvania
Justin
The last 53 blocks rolled off the line in the 2001 model year. I had a June 2000 built '01 that had a 53 block.
Little additional trivia, there were also quite a few 1998 12-valves that were also 53 blocks. We had one years ago at the shop that was cracked just like the 24's.
Interesting. I didn't realize there were so many different variations of 24v 5.9's. Most of my experience with them is in agricultural equipment, along with the 6.7 and the 8.3 big boy.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I think they, like other engine manufacturers, were all making changes in those years trying to comply with the EPA. 03-04 were unique, then they changed quite a bit again in 2004.5.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
UPS guy just dropped off some Cummins stuff. It looked as though the inner Gates box had been sitting around for a while. This got me excited. Inside were all Canadian and American made goodies.
Unfortunately, the most important piece in the other box is a Gates water pump…made in china.
oldretiredafguy
N. Texas
1988, 1988, 1991, 1983
350, 350, 350, 350
Correct. "Killer Dowel Pin" is just on 12v engines. 24v engines have the expensive engine block mounted lift pump. The Bosch VP-24 injection pump is cooled by fuel flow. When the lift pump weakens to less than 5 PSI, it craters the Vp-24. Very expensive to repair. Ask me how I know.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I thought the pump on this truck was called a CP-3. The lift pump on this one was converted to an in tank from the cylinder mounted by a Dodge dealer pretty early on.
Still, you should definitely pay attention to lift pump pressure and fuel filtering. A set of new injectors is about $3k.
Midnightmoon
Pennsylvania
Justin
His truck is a CP3. The VP-44 ended in the Dodge application in 2002. For the VP-44 trucks, fuel pressure was very important as mentioned above. Not so much on the Common Rail CP3 trucks. They will only see about 9psi at idle and can drop to 5-6 psi under load all day long with no issue.
The filtration is the biggest key to these common rail trucks. They really need to have a 2 micron filter added in the system somewhere to keep the injectors happy. I have mine installed between the factory filter/water separator and the head of the CP3.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I swear Cummins never made two engines the same. If you ever get a look at the spec books the variations will astound you.
ExtraZ
