The clutch is here, 4500 conversion done by New Years. You hear that @frankenchevy?
SquareRoot
My rad and the outlet is wider than stock. At $14 it's worth a try.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I agree. Price around here is $28 for the hose and $8 for a cheapy murray housing. Then about $12 in gas and 90 minutes of my life, lol!
Wider than the gas rad I’d assume. I don’t think anything wider than the one I have would fit. It goes from the battery tray all the way to the coolant overflow reservoir.
Maybe before I leave in the morning I’ll measure from radiator neck to fender and if your available you can repeat that measurement for me before I make the trek.
SquareRoot
Yes sir. Remind me in the morning and I'll get you the measurement.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Exactly 12” from flat part of inner fender.
SquareRoot
Wow. Your radiator must be huge. I don't think that hose is gonna work. Sorry about the delay, I've been at the vet all morning.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Yeah it’s on the bigger side. Well I guess I’ll be using the black accordion hoses...
thanks!
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
@SquareRoot , is it New Years yet? Are you finished? I bored over here waiting for rubber cement to set up. Did I just pull into the lead on this thing? I’ll be firing it up tomorrow morning. I wrapped almost all the odds and ends to the pro flo & nv4500 swap this afternoon when I got home. I even figured out a slightly less janky upper radiator hose solution out.
SquareRoot
Well call it a tie?!
Everything is in and hooked up. I'm going to fire it up in the morning. Took me awhile to bleed that damn clutch. I gravity bled it until all the air was out, tightened the bleeder and pushed the pedal. Straight to the floor. My vacuum bleeding didn't work for ****. So I found this tool at Napa. Didn't want to spend $60 but I didn't want to fight with it.
Got home, put a wrap of teflon tape on the bleeder screw threads, drained the system and went for it. I'll be damned!!!
It bled the clutch in literally 1 minute! No air, firm pedal and no mess. I'll never use anything else. Live and learn.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Yeah, I always put thread sealant on the bleeder screw when vacuum bleeding. Otherwise, you’ll keep seeing bubbles.
I like that guy though, don’t need a compressor.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I just called my local Napa and they’re ordering one in for me.
Just out of curiosity, how much movement are you getting on the slave rod? How firm is your pedal? Mine seems to fully disengage, but I guess I won’t know till I drive it a bit...
SquareRoot
Ya, pushing fluid up from the bottom is the way to go. The displaced air comes out the resovoiir and you just keep pumping until you get the fluid level you want.
I got a new pigtail wired in for the backup switch only to discover the switch was bad. Typical lol.
SquareRoot
About an inch. At first it felt weird, it would hit a certain point and then kind of roll over. I adjusted the rod about half inch and it stopped. It was going past the flex point or apex of the clutch fingers.
I just pulled the dust cover off the shelf. Damn! Looks like I gotta remove the starter if I'm going to install it. There's another hour in the morning.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
If you have a 1-piece rms you have to trim the dust cover a bit.
bglendon
