Taylorb27
- May 4, 2020
- North Dakota
- Taylor
- C10
So the th350c in my 84 c10 decided to leave a nice oil slick about 4 blocks to my house. Looks to be leaking from inside the bell housing as it’s leaking from my starter and somewhere on the driver side. Guessing the oring seal for the TC or a front seal? Anyway this is jumpstarting my LS swap project, I told myself I’d drive it stock until something happened.
I know I read somewhere that the 350c trans is not as strong as a regular 350 but I’d like to at least have lock up, so how would it do with a 5.3 that’s got a typical 220 cam? The trans will be rebuilt, have a higher stall converter, and have a tru cool 40k cooler or something like it.
Main reason for sticking with the trans I have is because the standalone ls harness I have is for a non electric trans set up.
I could try to find a 700r4 I guess for overdrive but I’d rather avoid setting up the tv cable even though Im using drive by cable on the 5.3
whatever input you guys have just shoot it my way! Thank you!
