tbi to carb
hiltijoe
ny
joe
custom delux
yep
gpmorgan
Tupelo Ms.
greg
I went back to tbi after numerous hours of jetting,drilling,changing metering blocks, power valves, etc. While I made it a lot better, it's hard to make a 1250 dominator completely streetable.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Regulating after is preferred, that way you have full pressure when you whack it, sometimes when they are regulated before, you'll see a dip on WOT.
spanky1205
Middle Tennessee
Anthony
Why not put a fuel pump on the side of the block that was intended for a carb in the first place and eliminate all the need for the wiring, regulators, and return lines, it worked great on my 350 and many others? The electric fuel pump is still in the tank and plumbed in I just pull the fuel through it with the new fuel pump on the side of the block.
Jrgunn5150
Ionia Mi
J.R.
6.slow
Depends on application. Stock and mild engines can get away with it, but hotter or power adder engines won't get consistent fuel with a unregulated mech pump.
yevgenievich
Place
Name
Year
Model
Size
Newer blocks also do noy have provision for the mech fuel pump
78silverado
