TBI to Carb 1991 V2500
big91burb
South Carolina
Jeff
Suburban 2500 Scottsdale
So can you use an adapter cable to obd2 then use an obd2 Bluetooth adapter? Or is there an OBD1 Bluetooth adapter
big91burb
South Carolina
Jeff
I'm not saying I'd rather have TBI than carb right now but I am intrigued hahahaahah.
gmbellew
Kansas city
glen
suburban 1500
Getting ALDLDroid from the Google playstore (about $20) and an OBD1 Bluetooth ALDL reader from 1320 electronics or Red Devil River (about $90) is what I recommend. I think 1320 may also have a free app you can use.
Tbi is dirt simple,very reliable and drivabilty and milage will be better with tbi. I'll take TBI over carbureted anyday,unless I'm running a lot of camshaft.
P.s. yes I have replaced tbi with a qjet,once because I was too lazy to chase down the parts I needed to make my tbi work with the engine I swapped. More headaches and hassles to make the carb fuel pump,and old school hei work than it was worth. And didn't have as good of set up when I was done as if I had just reworked the tbi.
big91burb
South Carolina
Jeff
Saying setup drivability wise or reliability wise? And let me ask this, if you where going on a road trip what kinda parts would you take for possible TBI issues? I usually try and stay prepared and bring parts that I think might strand me. Belts, hoses, fluids, tire repair, etc.... I know there's towing out there and I do have a 100mile tow plan but who wants to wait on the side of the road! Or worse on a dirt road trail if going out camping or something.
gmbellew
Kansas city
glen
suburban 1500
a spare ignition control module is about all I carry that is TBI specific. and then the normal stuff - fuses, fluids, bulbs, hoses, wires, etc.
Bennyt
Surprise
Ben
I'd definitely stick with TBI for a stockish motor. One of the reasons I bought my '90 was to get the TBI 454 over a carb. In theory it should have better mpg, better manners, etc.
TBI is pretty darn reliable and cheap to fix when needed. I knew a few guys that carry spare computers just in case and you can pick those up for a $100 if you plan ahead.
big91burb
South Carolina
Jeff
You can get a copied computer? I kinda figured they would need the existing to get the Vin out of it?
Everything wise. TBI is almost bullet proof most common failure is fuel pump IMHO. TBI gets good milage starts right up and drives good no matter what the outside temp, it compensates for barometric pressure. I was just too lazy to swap the TBI onto the carbureated. engine I was installing. So I had to regulate the fuel pressure run old school hei. So my timing and fuel control were not as good as if I'd run TBI. So drivability and milage took a hit, not a giant hit, but why spend any time or money to take any kind of hit.
KnuckleBuster
Floyd
I agree that TBI is almost bullet proof. I love the Quadrajet but wouldn't swap from TBI on a daily driver. Easy to work on and pretty much trouble free, as long as you stick with GM factory parts. I've probably worked on thousands of these and absolutely love'em.
I've seen in this thread and others where it is recommended to carry an extra ignition module. Don't know where this comes from unless they're using aftermarket modules. I doubt I've replaced a half dozen factory modules in all my years, but I have replaced a number of aftermarket modules.
I'd have to say that the 2 most common parts failures on these (that can leave you stranded) are the fuel pump and the ignition coil (yep, I carry an extra coil (nope, not an extra fuel pump)). But, that said, I don't think either has a failure rate that scares me.
Don't know how bad your wiring looks, but it's probably worth fixing.
gmbellew
Kansas city
glen
suburban 1500
I'd have to say that the 2 most common parts failures on these are the fuel pump and the ignition coil (yep, I carry an extra coil). But, that said, I don't think either has a failure rate that scares me.
I actually do have a spare coil I also carry. I had ICM issues, but they were aftermarket parts. I use Delco parts 100% unless I am in a pinch.
big91burb
South Carolina
Jeff
So we're talking ACDelco parts from a parts store? Or dealer? I figured dealer wouldn't stock most of the stuff for these trucks being 30 plus years old
big91burb
South Carolina
Jeff
And I know everyone talks about drivability and reliability but I've had some carbureted vehicles that drove way better and got better fuel mileage than stock injected vehicles. I have to a it's all in the carburetor tune.
KnuckleBuster
Floyd
The original thread post was "considering changing out to Carb and HEI in the future just for ease of service\roadside repairs", not about "drivability and reliability". Each system has its own advantages and disadvantages. I personally would be hard pressed to change from one to the other for any reason on a daily driver, and would NEVER change just for "ease of service\roadside repairs". But, that's just me. To each his own. My main point was just to say, as I have many times, that the TBI system is very easy to work on.
99tan99
