I was under the impression that TBI blocks don't have a mech fuel pump provision. TBH I haven't even looked at my block yet, maybe that's just a BBC thing? Would then the cam not have a lobe on for pump as well? My truck is a manual as well. That's why I'm researching this modification. Also what about pulling fuel through the electric intake pumps? Will the mech pump do it? My truck has dual tanks, so the switching shouldn't pose an issue. What are you going to do ECM-wise? Gut it or trick it into running? Pull the bulb on SES and go? When you say change the sending units to standard style what do you mean? Sorry for the mass of questions, but this really interests me.
No, the TBI blocks have the the bolt face for the pump and a factory block off plate and the hole in the block for the pushrod. And the earlier TBI era blocks still used a cam shaft that has the fuel pump lobe they just wernt used. Up to about mid year 1994 still had the lobe. You'll just need to find a pushrod from another small block. As far as I know they're all the same
I have no idea about BBC I'm talking SBC. I could ask my friend who has 2 90s big blocks.
As far as the sender units, what I meant by standard is the older mechanical pump style. A mech pump wont pull threw the electric pump, and if you remove the electric pump itll work fine, but the pickup tube wont reach the bottom of the tank, and wont have a sock. You'll need the older sender units or modify what you have.
The ECM im just going to leave there, unless someone wants to. Either just unplug it, or leave it as is and just let it have a panic attack, haha. It doesnt control anything I cant bypass, except maybe the gauges, but i can swap those out for an older full mechanical gauge set.
You'll have to put an 4 pin module HEI in it as well, that way the ignition system is a stand alone system. It only needs one power source, just needs a key on power.
As far as I know that's all you'll need, but I won't know until I get there.
