TBI Starting Questions
Jarrett Melvin
Newfoundland
Jarrett
Recently picked up an 89 C3500 C&C. 350 TBI, truck runs and drives. Issue is, truck is real hard to start cold, turns over 30-45 seconds before even making an offer. Put some gas down the throttle body and start right away and starts fine after its been running. PO mentioned a choke and that it was unhooked. Can't seem to find anything tho.
Any input greatly appreciated, thanks.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
TBI engines don’t have an actual choke. Check to see if the idle air control valve at the base of the throttle body is hooked up.
Does the fuel pump prime when you turn the key on to start the truck? If not, check the fuel pump relay.
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
Time to check the pumps fuel pressure. A new fuel filter might be the answer too if the pump checks out ok.
Sent from my SM-A705U using Tapatalk
Jarrett Melvin
Newfoundland
Jarrett
I was talking the PO afain and questioned him on it. He said " it be should be just unplugged from the side of the carb"
Could this be the TPS he's talking about?
It's anyone's guess what he is talking about. If it's TBI, there's no carb. Or choke.
Jarrett Melvin
Newfoundland
Jarrett
First time ive ever dealt with one, I understand there's no carb or choke. But I am only quoting what I was told when I bought the truck and came here in hopes someone could shine a little light in my problem or perhaps lead in me in the right direction as to what could be wrong.
Yeah, just don't worry about what the PO says. The first few responses here are the best place to start looking for the cause. Going off what the PO says is just going to have you on a wild goose chase.
ExtraZ
