TBI conversion
Randy Terry
Shaky
I was thinking of changing my carburetor 350 Chevy pickup engine to a TBI setup, it has the four barrel intake now and 4 barrel carburetor. it's a 1985 Chevy truck, what all has to be changed to make this work?
yevgenievich
Place
Name
Year
Model
Size
Make sure cam is TBI friendly, and then intake(or adapter) TBI unit, fuel injection lines, fuel injection gasoline tank, TBI unit, distributor, wiring and ecm.
I have almost complete TBI set up that I was planning to use, but not sure if it still going to be used or not
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
You can get a TBI adapter for the current intake, but the cleanest way to do it would be a TBI intake for pre-TBI heads. There’s also a carrier that holds a module, a solenoid, and a sensor, and you need the holes in intake to bolt it down. You’d need a spot to place a coolant temp sensor. You’d either need to unplug a port in the intake or get a water neck with a coolant temp sensor spot in it. You’d need a TBI distributor, ECM, wiring harness. The early 7747 ECM and wiring is the simplest and, in my opinion, most ideal setup. You’d need an ‘87 or later square body tank(s) because the old tanks didn’t have baffling for the fuel pump. And then the lines. Pretty much everything mentioned above with a couple added nuggets.
Randy Terry
Shaky
Thanks for the helpful info.
Randy Terry
Shaky
Why are you undecided about using you're TBI setup?
yevgenievich
Place
Name
Year
Model
Size
I just listed for sale the truck that it was for. But if it does not sell, TBI might find place in it. It is also almost same work as converting to ls motor for me because I need a fresher motor regardless.
psoccio99
