Elliot W
- Apr 13, 2021
- CT
- Elliot
- C10
I'm having an issue with my rear lights and can't find the problem. With lights off, both brake lights light up. With light on (both sides lit) and brakes applied, the drivers side brake light comes on but the passenger side goes dark. I assume I have a bad ground somewhere but going hand over hand of exposed wire I don't see any breaks in the wires al the way to the firewall. All fuses seem to be good visually. Is there anything past the firewall I should look at? Is it possible the socket is bad? Are there common areas on this harness for a bad ground? What is the best way to narrow down the ground with the voltmeter?
