Switching cluster types (please read)
mrnapolean1
'87
4.3 V6
I have an '87 SWB R10 Chevrolet that has the cluster with the "idiot" lights in it.
I want to switch to a cluster that has the gauges and prefer a factory tach (which is unheard of in these years)
If I was to purchase a cluster from a junk yard with gauges, how would I go about hooking it up to work with the gauges?
Or is there a way to delete the "idiot" lights and put my own gauges there?
Right now my gauges are mounted near the ground and I want to move them to a more visible area.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
You can go either way, there are several threads here about doing both. While not terribly complicated, there is a lot of wiring involved. A wiring diagram for your truck will be a good piece of information to have.
Where are you located in Texas, BTW?
mrnapolean1
'87
4.3 V6
In a tiny town called Venus.
What would be easier?
Boone83K10
Boone, NC
Benjamin
along with the wiring you would have to switch the senders too. idiot light vs gauge senders are totally different.
robert8096
Goose Creek SC
Robert
I just mounted a set of aftermarket gauges in the panel and mounted a small tach to the A pillar. It was a lot easier that swapping the wires around in the connector to match a factory gauge cluster. All I had to do was cut the area in the cluster pod to fit the gauges. You really can't tell when the cluster face installed.
I am getting ready to completely replace the wiring with a 21 circuit harness and when I finish with the harness then I am going to install the Dakota cluster.
mrnapolean1
'87
4.3 V6
Where did you get that cluster from?
I am eventually going to completely gut and redo this truck from the ground up.
Tdabney
