jake10
- Nov 25, 2022
- Ohio
- Jake
- C10
I got a 79 c10 long bed. The bed was absolutely rusted out beyond repair so i cut it up and am saving what's left it incase i need any sheet metal from it. I got a 87 bed that needs a bit of work but is much better than the other one was. However, the door is on the driver side while my actual gas tank is on the passenger side. My original bed had a door and not the cap only so I thought about cutting out the part on the drivers side and patching it into the passenger side and then just putting a piece of sheet metal over the hole in the drivers side. However , I also thought that it would just be a lot easier to use a hole saw and drill a hole right in the side for it and just clean up the edges a bit or put a screw on gas cap plate thing off amazon over it. I really don't care what it looks like as ling as its functional, what would be the easiest option.
