Swap Help!!!!
Aw man, a 4.3, stick shifter, 1/2 ton, foh-by. That's neat. :hump:
Yep.
Flex and Flywheel the same thing?
Sorry guys im still learning
Flexplate is for autos, flywheels are for a standard trans. Since the '86 has a flywheel for a 1-pice rear main seal type crank, it won't work in a motor witch a 2-pice rear seal. Otherwise, I've been told that the 4.3 flex/flywheel works on a 350.
And the dipstick went from the driver's side to the passenger side in '80.
Smitch320
The Southland
Mitchell
350/SM465 Short Bed
Thanks for the help Bucket
Basically same thing. Generally speaking and politically correct, an Auto trans gets a thinner ligher "flexpalate", a manual transmission get the heavier thicker "flywheel" that the clutch bolts to.
Yep.
DOH, OK so I needed to click to the next page. Here we go again with the READ, Put on your glasses comments !!! Shoulda known to ignore this one too. :emotions34:
:console:
:lol:
We can't tell you to read if you tell yourself!
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
I think the balancers/ balancing method are different for the 2 piece seal engines too.
philjafo
everywhere
phil
k20 scottsdale
350/sm465/np205/d44/corp14
I'm not certain but I think the 4.3 is externally balanced just like the smallblock 400, the motor mounts and fan shroud are different too you might run into some other minor differences but all easily overcame with a trip to your friendly neighborhood junkyard. Bellhousing and clutch are in the same spot and bolt up fine tho.
Smitch320
The Southland
Mitchell
350/SM465 Short Bed
So, Im looking at balencer, flywheel to make that motor compatible with my truck?
Smitch320
The Southland
Mitchell
350/SM465 Short Bed
Got a list of what I need to get to make this compatible with my 86.
Flywheel
Balencer
exhaust, and manifolds
distributor wires
While i am down there i am going to throw a new clutch on and replace the TOB.
Experts chime in, Thanks
Smitch
Smitch320
The Southland
Mitchell
350/SM465 Short Bed
Good news, Have motor built, but the motor mounts that bolt to the frame are different.
any ideas where to get them, went to junkyard and had no luck, Its a 4x4
blue900
