- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
Aw man, a 4.3, stick shifter, 1/2 ton, foh-by. That's neat.![]()
Yep.
Flex and Flywheel the same thing?
Sorry guys im still learning
Flexplate is for autos, flywheels are for a standard trans. Since the '86 has a flywheel for a 1-pice rear main seal type crank, it won't work in a motor witch a 2-pice rear seal. Otherwise, I've been told that the 4.3 flex/flywheel works on a 350.
And the dipstick went from the driver's side to the passenger side in '80.
