Merlin3e9
- Jun 28, 2018
- Crestview Florida
- Jason
- R10
- 5.7L
Evening everyone,
I'm about to pull the trigger on some parts to rebuild/upgrade the suspension & lower my 87 R10 and I've got a few questions.
I am looking at wanting to improve the handling of my truck, replace worn out parts and lower the truck roughly 2 1/2 - 3" up front & 4" in the rear. I like the slight racked look over a leveled look.
I've tossed around the idea of piecing parts together for the front end like new UCA's, all new polyurethane bushings, LCA bushings & ball joints etc..from Rock Auto or another source or buying an entire front end kit from Performance Online:
https://www.performanceonline.com/1...k-Tubular-Control-Arm-Suspension-Kit-Stage-3/
In trying to cost compare, the tubular control arm kit is a few hundred dollars more expensive, but I'd save time and labor since everything is already put together and no bushings will need to be removed or pressed in. Also, everything is already matched up and made to work together. Installation should be quick and painless.
My question for my front end is this... I was looking at going with their 3 inch coil lowering for the front end. Is this too much? I've read that you can have clearance issues from lowering more than 2- 2 1/2 inches up front with stock UCA's and stock 15" rally wheels. Is this the same with aftermarket tubular control arms? My plan for right now is to keep my original 15" rally wheels. My current tire size front & rear is 255/60-15. I might go to a slightly shorter and narrower tire up front and wider tire in back. (235/70-15 front & 275/60-15 in back) These sizes are the same height. I could do a 255/60-15 in front, but this is 1 inch shorter than the 275's.
I also have a factory sway bar. Will I need to replace the sway bar with aftermarket tubular control arms? If it'll bolt to the new control arms, then all I should need is new bushings right? Will a new sway bar make my truck handle better than the stock sway bar? I was also looking at a rear sway bar too. Here is a combo kit from performance online:
https://www.performanceonline.com/1...Sway-Bar-Kit-High-Performance-Front-and-Rear/
For the rear suspension, I want to do install lowered leaf springs for the rear versus shackles & hangers. I know shackles & hangers are cheaper, but I don't really want to cut my bed support in order to install longer shackles. Besides, I think my original leaf springs are sagging a bit. The drivers side is about 3/4 inch lower than the passenger. Could this be a bad shock? Do leaf springs go bad and sag over time? This truck has seen little to no duty as an actual truck, so I don't think they're worn out from excessive use. I don't think I have the HD suspension. I have 4+1 leaf springs in the back.
Here are the rear leaf springs I am thinking of getting:
https://www.performanceonline.com/1973-87-Chevy-C10-Truck-Multi-Leaf-Spring-Set-Rear-52-Long/
Of course matching lowered shocks would be installed on the rear as well.
Is their anything else I'm missing or should go ahead and replace? What about tie rod ends? I priced them from Rock Auto and they were less than $10 each for AC Delco.
My height measurements from the body crease line are:
DF: 37"
PF: 38 1/4"
DR: 39 1/2"
PR: 40"
Apologize for the long post.
Any advice or suggestions are appreciated.
Jason
DF: 37"
PF: 38 1/4"
DR: 39 1/2"
PR: 40"
Jason
