Dadof2
- Oct 31, 2014
- Central Texas
- Craig
- R1500 Chevy Sub, C20
- 350 in both trucks
We took our Suburban in for an alignment and the shop refused to do it because of work that needs to be done on the front end.
A couple of things up first:
A)We live in a small town and the shop comes highly recommended so I don't think they are just trying to run up a bill.
B) The truck has 257K miles on it and I wouldn't be surprised if it still has the original parts in the front end.
Here is what the shop says needs to be done:
Control Arm bushing x 2
Control arm x1
Left Upper ball joint x1
Inner tie rod x1
Adjuster sleeve (never heard of this) x1
Right Lower ball joint x1
Repack Wheel bearings
Invoice total 820.46 (310.00 for parts).
I plan on doing the work unless there is something involved that I can't do.
My question is this what is the best way to tackle this job? Can I do one side and then a couple of weeks do the other side?
Is there way to get the alignment close enough to straight to drive it to the shop (10 miles away)?
What else do I need to replace or should I replace while doing this work? They said left upper ball joint, but given the miles of the truck I was thinking about going ahead and replacing the left lower ball joint even though it's not listed.
Some additional back ground related to this truck:
This truck is a keeper, by that I mean short of being totaled it isn't going anywhere. We have switched over to older trucks to avoid car payments, because of the ability to work on them, and cost of parts.
So having said the above, I don't mind paying for quality parts and don't mind replacing things before they fail (in this case right side front end components).
I am trying to get our 81' C20 back up and running, but the Suburban is being an attention and money hog
Any thoughts would be greatly appreciated and Happy Thanksgiving.
Control arm x1
Inner tie rod x1
