- Apr 11, 2017
- kansas
- Rick
- c20
If you brush on a mixture of citrus acid and water.Keep it wet and keep rags with the same mixture over it the rust will dissolve.You can buy citric acid at the grocery store for canning..Now wipe it off wire brush it neutralize it.A quick sand and epoxy primer, and no more worries it's not treated rust it's gone rust.It will rust back up quick if you don't clean it and coat it.The stuff is amazing, not electrolysis good but unbelievably good.Electrolisis is like freaking magic, but not practical in this situation. N8ce thing about Epoxy Primer is its tough as nails, designed to go under body work and/or paint, and you only mix what you need to use.No 1\2 cans that you have to throw away.
