Superlift Kit from Summit
Yes, extended brake lines and likely extended drivelines too.
hirschdalechevy
norcal
rich
k-30
Can anyone think of some things that are necessary with a lift like this? I know brake lines are one thing. What about a transfer case drop?
http://www.summitracing.com/parts/slf-k420/overview/make/chevrolet
I don't mess around with any 80's truck's myself , (only 79 and under) but a lot of my buddies have them around here and we always drop the t-case if you have a 208 case with a 6" lift.
Here's what I would do , install the lift , check all the driveshaft's , (I would legnthen them) and u-joints . Then run her down the hwy. , if you have any vibration's you need to drop the case a little. Every truck is different , some guy's drop the case a 1/2" , some an inch , some not at all , (you have to play with it). I have one buddy that had his driveshaft made with a double cardain at the t-case end and that works well to. Just mess with it till she run's smooth down the hwy. and your good to go.
I would also get the frame brace kit from ord for the steering box to avoid problems later.
You will also need to drop the sway bar for a 6" lift if your kit dose'nt came with that , (I alway's throw my sway bar in the dumpster but thats just me).
BigBlue85
Tennessee
Joe
K10 Silverado
I've been looking around trying to tally up what all I would need. The frame brace I had forgot about.
hirschdalechevy
norcal
rich
k-30
You also might want to grab some hose to extend your axle vent tubes , (I like to route them to higher and better locations anyway for the deep water stuff)
Driver4r
Nebraska
Trevor
k10,c20
ben_swager
