Suburban Rear Heat & AC removal/installation/compatability
NCBurb
WNC
Suburban
6.2L
Howdy. My 87 Suburban did not come with rear heat or AC, but it does have factory in-dash AC. There's a guy parting one locally that supposedly has both, and I'm going to check it out this week. However, in doing some reading in old threads here, it looks like the rear heat was a completely separate unit from the AC? The AC is an overhead unit, and the heater was a floor-mount? Did some have one and not the other? With both, would there then be 4 lines running front to back? Does the AC tie in up front or is it a completely separate unit?
Other than power wiring and the control switches up front, is everything else pretty obvious as far as what I would need to remove to get everything? Any tricks or should it all bolt out pretty easily?
Lastly the parts rig is an 89, does that make any difference? Anything else to watch out for or is it pretty straightforward? All tips and advice appreciated, thanks...
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
My '89 has rear ac only. It seems like the heater units aren't that common, I've only seen pictures of them. Yes, the ac is tied in to the front system. Removing one would be pretty straightforward, the only part that might be tricky is where the rear lines enter the cabin at the back corner. It will look like this but I'm not sure how they come out.
I think I remember @89Suburban removed his ac from the back, maybe he will have some input when he checks in.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Those lines from that picture run up the farthest back, passenger side pillar, behind a trim piece. Then up into the ac housing and into a condenser up there.
here are a few shoddy pics of the rear heater parts:
496bb
AL
CL
Suburban R20
Reviving this thread, as I would like to add rear AC as well. I can see from the diagrams on of the parts sites that the compressor lines are different, allowing the rear lines to tie in. I have not been able to find a donor close by to pull it all from. Could a hose shop make the hard lines to run from front to back without it costing a fortune? I had one with rear AC several years back and remember having to get one of the rear hard/rubber lines repaired at a local hose shop.
Sometimes I have seen just interior the housings and internals with those lines available.
I looked into this several years ago, a local hose shop said it would be no problem to make new hoses to the rear. It would be flexible lines with the appropriate ends for connection.
I bought new GM hard lines in '06 I believe. They came as two pieces rather than one (for shipping and install purposes) which was nice. However, I only got about 5 years out of them before one corroded and blew out. That's why I wanted to go with hoses on the next go around. It was also proven to work well on many conversion vans of the 80's and 90's.
Corroded,did you evacuate it?
Yeah. It was a victim of salt and galvanic corrosion. It was at one of the factory retaining clamps.
76burb
texas
matt
suburban k20
If anyone is interested in a full suburban rear ac I have one down in houston that I’m about to remove. Just need to figure out how to disconnect it from the front unit and plug it off
DDropkick_pride
