Suburban Power Tailgate with new motor mod
Tonimus
Phoenix
Tony
C10 Suburban
If anyone has installed a "new" window motor in the tailgate of their Suburban, you may have noticed that there is very little engagement between the motor gear and the regulator gear. I think the motor gears and motor mount standoffs are just a little wrong. I cut 1/8" off of the motor standoffs, not including the little centering nub. If you count that, I probably cut off 3/16".
After I cut the standoff, engagement was good, but there wasn't enough room between the gear and the cover plate with the bushing. I did two things to allow the cover plate to fit and for the bronze bushing to still have enough support. I flipped the bronze bushing over, so the lip was on the outside. To hold the bushing in, I happened to have a starter shim lying around, and that was the perfect length to use as a retainer.
Here's a pic of the cut down standoff. I did all three.
Here's a pic of the whole install. Note the flipped end support bushing underneath the starter shim. I also added an extra ground wire since the regulator was kinda crusty and I didn't clean it.
I installed new rollers on the regulator. My regulator spring popped off, so I'm not sure how much tension it was supposed to have. I added 1/2 turn more than it seemed to want. This REALLY helped with speed and motor effort.
Below is how it works now. If you notice, at the end it slows down, where the spring is the tightest. And the spring tension really helps shoot the window up quickly. Before, at about halfway up, the motor would struggle to close the window. Now with the extra spring tension, I haven't had any more issues. I even changed my mind about running a new power wire and relays to the back.
I've installed a few new window motors many years ago and there didn't seem to be poor engagement at all. They were motors bought from GM. Maybe it's an issue with the newer reman units?
Tonimus
Phoenix
Tony
C10 Suburban
Probably. I got an eBay one. Cardone doesn't do them anymore. I didn't call GM, but it looks like most everything is the same chinese junk I got on eBay.
Curious how you wound the spring tighter. I've never attempted with that type spring lol
Ahh ok. I have a buddy with a 'burb that's always fighting with his back glass, I'll have to tell him about this.
Getting the spring tension right is a balancing act. If the window goes up slower than down, you need more tension. If the window goes up faster than down, you need less spring tension.
Tonimus
Phoenix
Tony
C10 Suburban
I had no idea prior to this. Trap for new gamers? Might have saved the last motor gear if it hadn't been fighting so hard.
Loo Dog
