Stumped, fender marker/turn light issue
Well, I can’t explain it but changed the front to incandescents but tried the LED flasher with incandescents and boom. Everything works! Perhaps the leds in the turn indicators on the dash are requiring the use of the led flasher even though I’m back to incandescents outside of the cab. Thanks to everyone.
yes, those are part of the resistance on the circuit. Needs to be incandescent unless the flasher is used.
Redfish
Prairieville, LA
Andrew
V1500
The use of LEDs for blinkers gets a bit complicated. It can be done reliably but it takes some doing. I have had very poor results with "LED Flashers".
Let's explain how the flasher works. Current flow through the flasher generates heat. Heat causes a bimetallic strip to bend and the circuit opens. It cools rapidly with no current flow, bends back and the circuit closes. The key here is current flow.
LEDs don't draw much current. Low current flow=not enough heat to make the flasher work. LED blinkers stay on and don't blink because the flasher doesn't have enough current flow.
In some cases we can install LEDs in the rear and keep incandescent bulbs in the front, the incandescent bulbs will draw enough to make the flasher still flash. The Square Body wiring schematic will not do this, the reasons were beautifully explained by @Turbo4whl .
The solution to this issue is made by Sylvania. A set of resistors that must be wired into the blinker circuit. They splice into the positive wire and then connect to any convenient ground allowing more current flow. Don't be confused by the resistor drawing more current, that sounds backwards BUT we now have an additional pathway for current to flow to ground. Now our flasher has enough current flow and the LEDs can blink.
In some cases we need 2 sets of these because we need one in the front and one in the rear on each side. In vehicles made before 1968 we usually get by with only one set because before 1968 we didn't have side marker lights and the blinker circuit was more simple.
the LED flasher I have in my f150 works fine, but then again I only have it up front led, rear is incandescent or else the transmission wont lockup Lol...
The lights will flash the same speed no matter what, if i pull a front bulb or add 3 trailers of tail lights, the thing that determines the flashing is a timer I guess not a resistance heat based kind
Turbo4whl
Downingtown, PA
Wayne
Jimmy
You can also use a preheated flasher. This one is salty but it works well. It will blink 1 #53 bulb or 10 #1157 bulbs. It blinks nice and slow, even makes your 1157's brighter because they are on longer and get full bright.
Preheated flasher
burnt
