- Oct 30, 2019
- Downingtown, PA
- Wayne
- Jimmy
Yes, triangle or arrow. The different types:
Schematic Symbol | Symbol Identification | Description of Symbol |
| Semiconductor Diode | Semiconductor pn-junction diode which passes current when forward-biased, and blocks current flow when reverse-biased. Commonly used in small-signal, rectification or high current applications |
| Zener Diode | Zener diode used in its reverse voltage breakdown region for voltage limiting, transient suppression and regulation applications. Available in a range of reverse breakdown voltage values |
| Schottky Diode | Schottky diode consisting of an n-type semiconductor and metal electrode junction producing a very low forward voltage drop and power dissipation and faster switching speed compared to a pn-junction diode |
| Light Emitting Diode (LED) | A semiconductor diode which emits a range of visible and non-visible coloured light from its pn-junction depending on the materials and doping used when forward biased |
| Photodiode | A semiconductor photosensor which allows current to flow through itself in the reverse direction when exposed to incident light energy |
