Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
I’m getting an early start on a couple of my winter projects.
I loaned my 20 foot car trailer to a friend. When he returned it to my house, he forgot to unplug the 7 way trailer plug. So now I’m replacing a bunch of wiring. I DESPISE scotch lock wire connectors!!!
My other trailer question, I’m lengthening the ramps. The existing ramps were 5 feet long, made of a pair of 3 inch C channel on either side, positioned like this ] [ with2 inch angle in between, covered with 11 gauge diamond plate.
My issue: I need to be very careful how I park when loading/unloading the car. If the ground is isn’t level (the truck is lower than the trailer, or the ramps are siting in a low spot) the exhaust will drag on the deck. Even if the truck/ trailer are level, the exhaust is closer than I would prefer.
My solution? I made the ramps longer, which improves the approach angle considerably. I added 2 feet to each ramp (which required a few modifications under the trailer for the added length). I welded matching C channel a angle iron to duplicate the existing ramps. I welded 15 inches of C channel to the flat side of the C channel, bridging the connection between the old/new ramps. I then covered everything with matching diamond plate. I’m not an expert welder/fabricator, but I’m pleased with the results.
Once it was all done, I stood back to admire my handy work. Now my concern, will the ramps handle the load? The trailer is rated at 10k. The heaviest truck I have had on it has been a 9600 pound 1 ton dually 4x4 diesel Ram pulling truck. I doubt the ramps will have any trouble with my 3900 pound Olds, but once I stood back and look at it finished, I’m a little concerned if I should ever need to put something really heavy on it I googled C channel load capacity, but the calculations and formulas are a little confusing.
Opinions?
Opinions?
