RanchWelder
- Jan 14, 2023
- Earth
- Blazer
- 355ci
I'm not perfect or feel the need to to be correct all the time.
I'm learning constantly.
Please teach me how what I wrote could be improper?
Not a physicist... not an engineer... just a human that cannot stand planned obsolescence.
Please test the cheap $89 ebait pump with a quality Winters or OTC Pressure Gauge before the return window runs out?
Mine came up short on a $390 Sonnex test bench at 5K ft.
You might want a proper filter on it, so the crumbs of aluminum from a cheapo vacuum, do not contaminate your A/C system or your transmission test bench.
What do I know?
My valves all tested good without leaks with less than 25 hg.
Improved nearly every valve and reamed for the extra diameter valve stroke bushings with the Sonnex kits.
Maybe I got ripped off.
What do I know?
