nvrenuf
- Jul 30, 2010
- Mobile, Al.
- John
- K5
Man, you guys go straight for some of the most elaborate stuff first. If you had a miss would you rebuild the motor before trying a tune up????
Motor won't turn over - check battery voltage, if less than 12.6v charge the battery. If fully charged, tested good and still no crank, check for power at the starter (loose connections, fuse link,etc).
Check the alternator - not charging can kill a battery and/or vehicle.
Start Wth the simple stuff....
