Steering Gear Box Adjustment
cah2873
East Texas
Chance
I have had new ball joints and alll front end components installed in my 84 K20. The rag joint and steering shaft is also tight. The truck drives 80% better than before. I noticed that the gear box has quite a bit of slack from the time the steering wheel engages and the output shaft for the pitman arm moves. I read some forums on how to adjust the box. So I did this evening. It moved about 2 full rounds down before getting tight and then I back it up 1/2 round. I moved the steering wheel to lock in both directions and it felt good without any binding. The slack did tighten up considerably but I have not driven it yet. Is this safe to drive? Or should I go ahead and get a new box? Thanks in advance.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I've played around with the gear box adjustments for years on old, new, and rebuilt. I could never get all the play out of them for the life of me. Especially on lifted squares with big ass tires. I gave up on it sometime ago, I figured it is what it is, its not rack n pinion.
kdo58
Puyallup wa.
k5
I would get a nappa box, made a world of difference in my truck.
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
I just put a new (reman) box on my too, and it was a night and day difference.
cah2873
East Texas
Chance
I drove it a while this evening. It helped but probably needs a new box. I called NAPA and they can get one for $158.00 and it USA Cardone brand. Will this be a good replacement? Secondly, how hard is it to install?
1low4x4
Nick
Sounds like a good brand. They aren't hard to install. Did you make sure the bolts that fasten the box to the frame were tight? Mine was loose and it allowed a lot of play. I replaced mine with a new unit and wasn't impressed with any sort of improvement, I agree with VAL that theres only so much tightness you can get from the ****** drag link design
Georgeb
Wisconsin
George
K10 Burb Z71
Should be good. Installation isn't too bad. You will need a socket that will
Fit the large nut for the pitman arm as well as a pitman arm puller. If you are planning to reuse the pitman arm you may be able to pull it off the old gear without separating the other end from the steering linkage. Otherwise you may need a separator fork as well as a new boot and a cotter key. You can get the taper on the linkage end apart using this concept and save the boot.
https://m.youtube.com/watch?v=LDsci-izhhc
kdo58
Puyallup wa.
k5
The nappa box is lifetime guarantee. I figured it must be pretty good if they give a good warranty.
iandrake
